Head gasket
Old Oct 20, 2003 | 04:03 PM
ARACER25's Avatar
Default Head gasket
I am looking for a headgasket and I want stock thickness but duriability.
Old Oct 20, 2003 | 04:29 PM
9200RPM's Avatar
Default Re: Head gasket (ARACER25)
I voted OEM simply for the price...they are much cheaper to replace if need be...
Old Oct 20, 2003 | 04:32 PM
ARACER25's Avatar
Default Re: Head gasket (TurboB16aEG)
But which one is stronger?
Old Oct 20, 2003 | 05:23 PM
93LSivic's Avatar
I voted cometic. I recommend them in all my builds. Even the one I have on my current setup was RE-USED from my old motor setup. Just add some copper spray and call it a day.
Old Oct 20, 2003 | 10:41 PM
89dxhunchback's Avatar
Default Re: Head gasket (93LSivic)
I see nothing wrong with the Mr. gasket MLS gasket that summit sells for $40. Get some ARP head studs while your at it, then the gasket won't give you any greif unless you give it GOOD reason to.
Old Oct 20, 2003 | 10:46 PM
Full-Race Henry's Avatar
Default Re: Head gasket (89dxhunchback)
i just use a cometic hg, copper spray, and arp head studs.
Old Oct 21, 2003 | 07:36 PM
9200RPM's Avatar
I have OEM 3 layer, ARP studs, and copper spray....no probs yet...well see after turbo setup is complete...
Old Oct 21, 2003 | 08:28 PM
jmal1919's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89dxhunchback &raquo;</TD></TR><TR><TD CLASS="quote">... then the gasket won't give you any greif unless you give it GOOD reason to....</TD></TR></TABLE>
can you explain further?
Old Oct 21, 2003 | 08:40 PM
B16A1-EF9's Avatar
I'm building my motor now for boost. My machinist suggested Wiesco pistons. When I called Wiesco they offered me a package deal for the pistons and the headgasket, anyway, it's Cometic Metal gasket...
Just wondering what everyone has to say about these for high-horsepower - high-boos applications. Any problems so far with them? Any input is appreciated.
Old Oct 23, 2003 | 07:20 PM
ARACER25's Avatar
Default Re: (B16A1-EF9)
What kind of deal did they give you?
Old Oct 23, 2003 | 07:22 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (ARACER25)
i have a cometic right now, 84mm b16 but when it was a stock bore, never any problens with a stock head gasket.
Old Oct 23, 2003 | 07:35 PM
B16A1-EF9's Avatar
I payed 100 bucks straight from Wiesco.
But has anyone really had any problems with high-boost on this head gasket? I'd like to know exactly what I'm getting into before I do.
Thanks again
Old Oct 23, 2003 | 07:37 PM
ARACER25's Avatar
No I mean the deal for everything? Pistons, rings, pins, gasket...
Old Oct 23, 2003 | 09:02 PM
Default Re: Head gasket (jmal1919)
I meant if you don't over-heat the car or hit it with a lot of knock..
Also look into "halimar" ( spelling may not be correct ). Bently invented "halimare" to help seal the head gaskets on there TT-V12's, now perminex is licenced to sell it here in the US. All the GN guys say its the ****, and you can't argue with the Bently...
I used copper spray, ARP head studs, and Mr. Gasket MLS gasket, but I'm going to use the "halimar" on my TT stealth.
Civic head = 3 hours ( ON AND OFF )
Stealth TT heads = 2 1/2 days JUST TO GET THEM OFF !!!
Old Oct 23, 2003 | 10:31 PM
S2KP's Avatar
Are there any advantages to copper spraying a headgasket?
mooneyestwo
Oct 7, 2014 10:14 AM
Brycen
Jan 1, 2010 02:20 AM
Agito
Sep 29, 2008 02:18 PM
proda9driver
Jan 9, 2008 08:23 PM
CoreyR
Sep 22, 2004 11:02 PM
