Cylinder Support Systems
Hi so I recently had the pressure plate explode on my b16a turbo build, and it took out the transmission front housing and broke the block where the transmission bolts to the block. So I am looking for another b16a block to throw my set up in. Question is has anyone ever done the CSS machine work to a turbo B16a application and how did it hold up? How did you like it? Is it worth it? What kind of power where people making on it with stock cylinder walls with just the CSS machine work done to it? I will be throwing 81.5mm 10.1 cp compression ratio pistons and eagle rods into it, so would I have to get the block bored before I sent it to them? And just trying to see what kind of power people where getting out of them. Thanks in advanced
KFBhonda
Sep 8, 2011 03:24 AM
Unsung
Jun 16, 2003 05:38 PM
