Low compression from cracked manifold??
Old Mar 23, 2020 | 01:15 PM
charlyhtx487's Avatar
Default Low compression from cracked manifold??
Hey fellas, well I've been going through my daughter's car. Was getting misfire on number 2
Anyway, did a compression check and number 2 was low. Well I happened to remove the heat shield today from the exhaust manifold and they'res a crack starting from the O2 sensor and ending towards the pipe going to number 2. Can a cracked exhaust manifold cause low compression and a misfire in that cylinder? I'm thinking maybe that's my problem and not the head
Old Mar 23, 2020 | 07:08 PM
chrysler kid's Avatar
Default Re: Low compression from cracked manifold??
No it wouldn't cause low compression, misfire yes
Old Mar 24, 2020 | 05:01 PM
muellersfan's Avatar
Does the crack happen to extend to the head? If not, it's a separate problem, as mentioned.
Old Mar 25, 2020 | 09:28 PM
eghatch9295's Avatar
Stancetard Hate Monger
problem isn't necessarily the head, either. you need to do a proper compression/leak down test
MountSolonDA
Sep 3, 2015 08:34 AM
flatblackintegragsr
May 27, 2006 01:46 PM
stupidfast
Oct 20, 2002 03:50 PM
X2BOARD
Jun 11, 2002 09:49 AM
