B20 crank and rods in a b18c1
Old Mar 18, 2020 | 06:49 AM
purposebuilt's Avatar
Default B20 crank and rods in a b18c1
H I'm building a gsr bottom end. By useing a b18c1 block and useing a b20/ls crank and rods and was woundering what bearing do I use for the main caps do I use the gsr since it's a gsr block and caps or do I use b20 since it's a b20 crank I know to use b20 rod bearing since it b20 crank and rods but unsure about the main bearings. Please help
Old Mar 18, 2020 | 04:32 PM
K20.ek's Avatar
Default Re: B20 crank and rods in a b18c1
use B20/LS bearings on mains and rods.
I have the same setup except I’m using LS crank/rods in a gsr.
Old Mar 18, 2020 | 10:43 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
GSR and B20 main bearings are the same part numbers from the factory. The rod bearings are different.
TurbodTegSfaria
Oct 5, 2009 03:36 PM
dannyneedshelp
Oct 15, 2008 04:22 PM
H23vtecEG
10
Jan 22, 2005 02:34 PM
XSBoost
Jun 12, 2001 10:46 AM
