Oil pissing out back of engine
At first i thought it was my rear main, but after wiping everything down It looked like it was coming from my oil filter. I have an oil sandwich plate for my turbo but it doesn't seem wet around that area and after removing the sandwich plate it and putting on a new oil filter it still leaks. I don't believe it is the oil filter.
Things that I have done recently:
New poly motor mounts
New headgasket, arp head studs (done months ago, hasn't given me issues)
New intake manifold
Turbo installed
Rear cam seal area is dry.
The leak is a steady stream, no dripping just a straight up drizzle of oil.
New intake manifold
Turbo installed
Alright so it appears to be my oil pan. When I jacked up the motor a few weeks ago to do the motor mounts i heard a large crack and didn't think much of it. I might as well buy a new on and get my turbo feed welded into it.
Does anyone know if non-honda oe oil pans are good. I dont want to but I'll buy oem if i have to. Are the y7 pans steel?
2018HBowner
Honda Civic (2016 - Current)
12
Jul 24, 2019 04:01 AM
