how to fix p28 crank sensor error code 4
hi guys, i know this has been posted so many time just wondering how to fix this issue error code 4 on p28, i am using obd0 harness, and obd2b dizzy from b18c7 2000 teg type r
do i have to bypass it, seems i cant find the answer to this , provide me with link if there is .. thank you
verify your wring from ECU to distributor.
Do electrical continuity checks.
Also check inside the distributor and check that all wires are in good condition.
Other than that, try a different distributor.
yeh, i am checking right now... i am so confuse with ckp cyp tdc, where it suppose to go..
because i am using ebay obd2b dizzy conversion to obd0 ,, obd0 engine harness,, obd1 p28 ecu with obd1 to obd0 conversion ecu plug
your crank position sensor is in the dizzy
but just becasue you have a code 4 does not always mean that your sensor is bad
a 02 sensor that is not connected right will also throw a code 4
that p28 ecu you have will be looking for a 4 wire o2 sensor
so make sure you have that hooked up with your jumper harness
hope that helped
hope that helped
hope that helped
hope that helped
TwoFacedCustoms
Oct 15, 2010 06:05 PM
