Crank no start PLZ HELP!!
Old Mar 4, 2020 | 08:45 AM
CGarrison3822's Avatar
Default Crank no start PLZ HELP!!
92 civic EX 1.6L
CEL Code 0
Ive already changed fuel filter, fuel pump, plugs, and main relay.
I have spark and fuel pressure
Coil is good
I think its a grounding issue because it did start twice but ran very poorly and died.
Checked all my grounds and wires in the engine bay and all seems to check out.
I think the next step would be to check the ECU ground. Ive located the ECU however at this point I need further instruction on what to do?? Or maybe could be a whole different issue altogether???
Would really appreciate some thoughts on this, THANKS
Old Mar 4, 2020 | 10:48 AM
muellersfan's Avatar
Default Re: Crank no start PLZ HELP!!
Originally Posted by CGarrison3822
92 civic EX 1.6L
CEL Code 0
You don't have CEL code 0 if you have fuel pressure and spark.
Check the mechanical timing.
Old Mar 4, 2020 | 10:33 PM
Quicksight87's Avatar
good suggestion. Maybe belt slipped a tooth?
when my civic timing belt was off a tooth it still rand just had no top end power tho 🤷🏽‍♂️
Elijahdaniel
Feb 27, 2016 07:07 PM
attia
Oct 30, 2014 04:41 AM
95turboeg
11
Jun 13, 2013 03:51 PM
pbizzlegsr
Aug 27, 2004 08:55 AM
