B16a2 vtec not engaging
Hi all im from the UK
Can anyone shed some light, have a b16a2 swapped civic and it’s got the later vtec solenoid with no pressure switch.
Recently just fitted the hondata s300 ecu p28 and uploaded the jdm b16 p30 base map.
I disabled the knock sensor and the oil pressure switch in vtec parameters. Car is still not going into vtec.
I checked the vtec solenoid and thats fine. Have car booked in to get mapped soon as it’s running a bit rich atm and needs mapped. Car has zero fault codes showing.
How can you tell the car isnt going into vtec? I have a bone stock em1 with alot of extra sound insulation and I literally cant tell if vtec engages. Is there a light or something you can install?
You can T in an LED into the vtec signal wire. I have seen people install a light in their cluster to signal them Vtec engaged.
K20.ek
Sep 27, 2019 10:15 AM
gurlugotmilk
22
Jun 6, 2007 10:08 PM
Asin
Jul 5, 2004 05:48 AM
