Gas smell on oil/Smoke at high rpm
Old Feb 20, 2020 | 07:08 AM
AMRF's Avatar
Default Gas smell on oil/Smoke at high rpm
Hello everyone,
I got an EK3, D15Z6 engine (1.5 VTEC-E), and in the last couple of days I noticed a gas smell on the oil dipstick.
Yesterday, when revving it up to high rpm (+5K), there was a blue-ish/white smoke coming off the car.
It turns on perfectly when cold and hot, and there is no visible smoke on idle or low rpm.
The idle is constant at 750rpm, and the fuel consumption is also normal. No strong odor of gasoline outside the car on idle, also.
The car went to a major check about 800 miles ago, changing all the oils, filters, distribution, etc.
Before running a compression test, what can be expected from these symptoms? Piston rings?
Thanks.
Old Feb 20, 2020 | 07:49 AM
Freedo_Civegra's Avatar
Default Re: Gas smell on oil/Smoke at high rpm
Oil smells like gas? Rings.
Old Feb 20, 2020 | 08:53 PM
oldman9's Avatar
Has it started using more fuel than normal? How do your plugs look after running?
I've had an injector not close all the way and give way too much fuel.
Old Feb 21, 2020 | 03:07 AM
AMRF's Avatar
Thanks for all the help.
The fuel consumption seems normal, the plugs have been changed recently, 2 weeks ago.
Maybe it is one of the injectors... Is it possible that when adding the STP fuel injector cleaner made this happen?
I recently added it, and it was since then I noticed this odor on the oil.
Old Feb 21, 2020 | 06:32 AM
muellersfan's Avatar
Replace the engine oil. Then monitor whether the fuel smell returns without the cleaner treatment.
Hyaboosta
Jul 26, 2005 04:48 PM
19sec beast
Jul 21, 2005 05:11 AM
Layziebtnh055
May 12, 2004 01:20 PM
Layziebtnh055
11
Apr 21, 2004 03:24 PM
