Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Map Lights
Old Feb 9, 2020 | 08:23 PM
Devon Nullman's Avatar
Default Map Lights
2004 Accord EX V6 - Passenger side map light comes on when door is opened, shuts off when closed after a delay. Switch is in the "DOOR" position. Drivers side does nothing, if I push on it, the light comes on with doors open or closed, but then does not turn off until I press the lens again.
Old Feb 12, 2020 | 09:22 AM
Eugene1979's Avatar
Default Re: Map Lights
Clean or replace the switch under the map light, i replaced mine - some claim all you need to do is clean.
super cheap on ebay, easy to do as a DIY, search youtube
Ebay
Old Feb 12, 2020 | 12:54 PM
Ebay
Thanks very much, that was it, I took out the switch, cleaned the contacts with a Q-Tip and alcohol, put it back and all is well - I probably will order a pair anyway.
Old Feb 20, 2020 | 04:32 PM
NightHawk92's Avatar
I have to buy the same Map light Switch base mine is doing the same thing at first i thought it was just the bulbs where burned out. replace those then after 6 months. the Light on drivers side would not come on. took it apart seen the white plastic plunger has corrosion.Its $60 part so for permanent fix have to replace it.
woj
Feb 13, 2018 06:17 AM
crazyhouse2011
Aug 12, 2014 04:32 AM
XIV
Aug 7, 2014 06:51 PM
GRIM$
Jul 14, 2014 12:59 PM
tegG2
Sep 9, 2007 06:06 PM
