Hydraulic Issue or Clutch Itself? Clueless.
Old Feb 9, 2020 | 07:31 AM
Simon Tibbett's Avatar
Default Hydraulic Issue or Clutch Itself? Clueless.
Hi all, so I had an issue where it became impossible to get the car into gear. If I pumped it I could get it in gear with a clunk but not smooth. It seemed hydraulic given the change if I pumped it. So I replaced the clutch master and slave cylinder. I bled the system quite a while and now only see new fluid and no air. However, the issue is still there albeit it feels a tiny bit better on and off. Still not trustworthy of driving.
Any ideas? Is it the clutch itself or something internal? It feels like it would if you don't have the clutch all the way pushed in, trying to shift. It's not disengaged all the way. Could pedal adjustment fix it?
Old Feb 9, 2020 | 08:12 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Hydraulic Issue or Clutch Itself? Clueless.
Maybe... get someone to push the clutch pedal for you while you LOOK at the slave cylinder and release arm movement. What is the distance traveled when the clutch pedal is moved from all the way out to all the way in ?
Old Feb 11, 2020 | 04:14 PM
I got a rough measurement of around 2.5 inches or so. It doesn’t look like a lot but I’ve never paid attention to how much it moved before so...
Old Mar 16, 2020 | 08:32 AM
Anyone else have any ideas before I take it somewhere to drop the transmission? I don't know if bleeding it more will help, the pedal isn't adjusted right, etc. I've done it all by the book I THINK.
Old Mar 16, 2020 | 08:53 PM
JRCivic1's Avatar
10 Year Member
Community Builder
That is a lot of travel... does the pedal feel harder to push as it gets close to the floor ??? Almost like something is in the way or impeding the pedal arm ???
Old Mar 17, 2020 | 01:47 PM
The pedal feel itself is pretty normal feeling. It has always had some play at the top of the travel when pushing the clutch.
mrcoolhead
Jan 30, 2013 06:12 PM
91SI92
Apr 23, 2011 11:44 PM
lxdriver
Feb 26, 2011 07:28 PM
Fullthrottlegsr
Jun 22, 2005 01:21 PM
Aceman64
Dec 18, 2001 07:23 AM
