99 civic ex harness on b16a2
Old Feb 5, 2020 | 10:37 PM
Glez_irvin's Avatar
Default 99 civic ex harness on b16a2
So I have a 97 civic ex with a b16a2 off an 99-00 si. Im planning on swaping out the engine harness because dont think everything is hooked up on right. So I have a uncut engine harness from a 99 civic ex 5 speed vtec what would i need to do to make it work on the b16a2 running on the stock p2t ecu anyone can point me to the right direction?
Old Feb 6, 2020 | 07:53 PM
EWY's Avatar
EWY
Default Re: 99 civic ex harness on b16a2
The issue is that your car is an Obd2A and the Engine harness is coming out of an obd2B. To my knowledge if you try to install the 99 civic ex harness it will not connect to your cabin harness. If your are trying to stay obd2 you can try and source an obd2a ecu from a Honda Del Sol. Some Honda Del Sols came with a B16A3. You could also try and get an obd2a to obd2b ecu jumper harness.
whyS0serious
33
Mar 28, 2012 10:50 AM
da59block
14
Nov 11, 2011 12:33 PM
pootie.teng
Feb 12, 2004 01:16 AM
Team 4R
Dec 16, 2003 03:58 AM
