Help! B18 Milled head Cam gear off
Old Jan 24, 2020 | 04:03 PM
Mfsmoov's Avatar
Icon5 Help! B18 Milled head Cam gear off
EDIT: DEGREE YOUR CAMS!!! Always triple check your work and dont over think things.
Old Jan 24, 2020 | 09:37 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Help! B18 Milled head Cam gear off
Your exhaust cam gear is one tooth advanced. It has nothing to do with milling the head.
Old Jan 24, 2020 | 10:26 PM
Mfsmoov's Avatar
When I tried timing it with everything at TDC I got no luck
Old Jan 24, 2020 | 11:14 PM
Mfsmoov's Avatar
Icon5 Help! Cant set ignition timing B18
So I think I managed to set the cam and crank at TDC with the stock cam gears. I started the engine and tried to set the timing and my distributor was fully advanced. When fully advanced I was not able to even reach the 12 degree mark on the crank pulley.
Any clue?
Old Jan 25, 2020 | 06:22 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Please keep all of this together in one thread. It's all related and having all the details, trials and errors in one place makes it easier for any who help you.
Thank you.
Old Jan 28, 2020 | 02:34 AM
NVturbo's Avatar
O.G. triple O.G.
set everything back to TDC, first the crank pulley, then the cam gears. Rotate the engine CCW at least one full revolution. If the crank pulley is back at TDC, the 2 cam gears should line up correctly.
On another note, why are you putting all those blue silicone on the spark plug holes and between the cam gears? A brand new valve cover is like $20.
Old Jan 28, 2020 | 10:15 PM
Mfsmoov's Avatar
As Stated in the post. Previous owner did the gasket maker. Ive since degreed my cams and worked out whatever issue I was having.
I tried to delete the post.
But Instead ill just upload some pictures of the swap and car here in a few days once its all finished up.
OH_1fstgsr
Jan 24, 2010 06:10 PM
kpjo4
Jul 11, 2009 06:44 AM
Steezn4NOReason
Jan 10, 2005 07:50 PM
Brewer
Jan 13, 2004 10:58 AM
Tofurky
Dec 7, 2002 01:06 AM
