phirewire's 99 GSR Turbo Restoral build thread
Old Jan 21, 2020 | 12:05 PM
phirewire's Avatar
Default phirewire's 99 GSR Turbo Restoral build thread
I have a 99 GSR (B18C1) that I purchased from auction with a ebay turbo kit, I've gone and replaced feed/drain and turbo and still have a issue with it blowing oil out the exhaust. Now I understand this to be like 3 things,
1: Poor Drain
2: Bad Seals
3: Engine issues
and from what I can tell; 1. I installed a new 10 an line with a straight / 45 and turbo drain is pointed down off about 10 degrees not quite straight down but fairly close. 2. I have installed 2 different turbos and continue to have this issue at idle the car doesn't smoke only when you give it rpms does it start pouring out the exhaust. 3. I have no oil coming from manifold.
Now I am still lost but I do have a belief to the issue, The car came with a moroso oil pan. https://shop.redline360.com/products...RoCFvQQAvD_BwE
And its said to have 4.1 qt capacity, and comes pre-tapped for a drain. What I noticed is when filling the oil at about 2.5 qts I have oil draining out of the oil drain. This is what I believe to be the problem but what I can't figure out is how others can use this pan and not have it as an issue, also its the same as a stock pan just baffled. What options do I have?
Old Jan 21, 2020 | 12:20 PM
BoostHatchFreak's Avatar
Default re: phirewire's 99 GSR Turbo Restoral build thread
Valve steam seals, do a compression or leak down test make sure to check the engines Health
Old Jan 21, 2020 | 12:27 PM
phirewire's Avatar
I'd have blow by from exhaust manifold if this were the case?
Old Jan 21, 2020 | 03:21 PM
ls joker's Avatar
Loved
Is it an ebay turbo, does it have a restrictor, oil could be backing up in the drain line. Should prolly just come straight down for the drain. Other than a 45 fitting, i imagine is on the turbo. You the drain line as inline as possible. Please provide pics.
Old Jan 21, 2020 | 03:29 PM
phirewire's Avatar
running a .035 restrictor as recommended by turbo. I have actually taken a bit out of the Line as well about 1/2 inch shorter.
my drain as requested=
Old Jan 21, 2020 | 05:07 PM
TheShodan's Avatar
Moderator
Default Re: 99 GSR Turbo Restore
Yeah, an eBay turbocharger with a .035" restrictor. There's your problem right there. Those eBay ones are not GT turbos with sealed bearing cages in which little oil is needed. You've killed it inadvertently, and now you must replace it. But that return line routing seems a little suspect too. Hard to do that with those things.
Old Jan 22, 2020 | 09:15 AM
phirewire's Avatar
Not really a way to improve the routing of the drain, based on the layout. Though I don't believe the turbo is "killed'. The car hasn't been driven or run long. Just started and brought up a bit in rpms to see if it smoked. The part I am lost at is It smokes when up it RPMs which your attesting to bad seals from not enough oil, the last turbo I had I didn't run it with a restrictor instantly and had the same issue.
Old Jan 22, 2020 | 09:22 AM
TheShodan's Avatar
Moderator
Just because you aren't running the car on the road doesn't mean that you're not causing damage by way of backflow from the return line or possible starvation from having the wrong restrictor in there. Even at idle, these compressor can easily spin at over 20,000rpms. And that's just you sitting there.
Well, You know.....what you know.
Old Jan 22, 2020 | 09:33 AM
phirewire's Avatar
To be clear not arguing, just learning and questioning.
So your theory is a mix of turbo and drain line. any thoughts on these Moroso pans draining out of plug?
Old Jan 22, 2020 | 09:57 AM
TheShodan's Avatar
Moderator
No argument here. Just emphasizing a different point of reference.
I just think that the oil drain point itself was horribly designed and never intended for a turbocharger that had high oil requirements. even the road race versions are at least a better option
Old Jan 22, 2020 | 09:58 AM
phirewire's Avatar
Recommendations on a solution?
Old Jan 22, 2020 | 10:02 AM
TheShodan's Avatar
Moderator
Go back to a stock OEM pan, reconfigure the oil drain line. Contact your eBay turbo seller and find out the type of CHRA that you have. Then use the appropriate restrictor on a clean oil feed line, if at all needed.
Old Jan 22, 2020 | 10:48 AM
phirewire's Avatar
Pan dimensions are the same your more or less saying relocate the drain closer to the turbo vs the right side of pan.
Old Jan 23, 2020 | 03:29 AM
TheShodan's Avatar
Moderator
the oil pan has the same dimensions, but has the depth at a more ideal location where backflow would be less of a possibility
Old Jan 23, 2020 | 11:02 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: phirewire's 99 GSR Turbo Restoral build thread
Put a 45' hose end fitting at the pan end of the drain line as well and this will minimize the low area that allows oil to back up in the line.
PR8urVtec
Sep 26, 2015 03:02 PM
cehcivic15
Apr 12, 2013 02:26 PM
teal_dx
Nov 29, 2009 01:09 PM
boostedcoupe1
Feb 16, 2008 06:46 AM
hold your breath
Feb 14, 2007 10:01 AM
