Honda Civic Ek3 1997 Ferio - RPM fluctuate from 300 to 1100
Hi everyone,
I am having following issues with my Civic 1997 Ek3 (D15b engine) RPM
Thanks
- Issue 1: RPM fluctuate from 300 to 1100 when engaging A/T gear. On neutral it stable to 900. But when the car starts running more that 10 km speed, the fluctuation stops and rpm stay steady. I have changed the throttle body but didn't work.
- Issue 2: After Engaging the AC or headlight the RPM falls a bit instead of increase and compensating the load.
- Issue 3: Passengers smell Gasoline inside the cabin (rear seat) when I accelerate heavily. Fuel consumption increased. I have checked the fuel pump found ok. No Fuel licking from tank and near Fuel injectors. But can smell Gasoline from exhaust.
Thanks
1) Open heater valve near firewall wide open.
2) Top off radiator and reservoir with coolant.
3) Idle engine with the radiator cap loose until radiator fan turns on at least twice.
4) Top off coolant in radiator level dropped during bleed.
Bleed = remove air from cooling system
hyper em1
Mar 5, 2006 07:25 AM
BoostedD15B7
Jul 3, 2002 05:26 PM
