Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2006 R18 decided to start cracking
Old Jan 13, 2020 | 01:53 PM
4drEF's Avatar
Keyboard Humorist
Default 2006 R18 decided to start cracking
Confirmed that it is the notorious engine block crack over by the alternator that starts leaking water.
It's long out of warranty for getting the block replaced so I removed the exhaust and thermostat housing+water tube to expose the crack.
There is a small pocket by the freeze plug that is leaking so It doesn't look like I'll have enough room to get a welder in there.
Assuming I'm going to have to resort to JB weld.
Anyone having long term success with this method?
I am hoping to get a year or two out of it.
Old Feb 15, 2020 | 07:08 PM
Chrisfrom1986's Avatar
Default Re: 2006 R18 decided to start cracking
I think most people just get the 08-11 block and hope for the best with any replacement. I have an 07 dx with 137k that's been sitting for a year and a half waiting for me to swap in an engine.
Old Feb 17, 2020 | 03:13 PM
4drEF's Avatar
Keyboard Humorist
I gave the JB weld a try and it has slowed the leak.somehow it's still getting past the JB Weld so I'm going to add more.
Thinking I will have to replace the block eventually, but I would like to get some more miles out of this engine if I can. It is running very well other than the leak.
Old Feb 17, 2020 | 03:22 PM
Mine mixed oil and coolant, I never got around to inspecting the block. I'm hoping it was just a head gasket from using straight water.
Old Feb 19, 2020 | 05:03 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
As requested, irrelevant post removed (no activity from user) and thread re-opened for discussion.
Old Apr 30, 2020 | 08:11 PM
So I finally got around to taking a look at my situation. I've got a tiny hole on the back of the block under the breather cover. Cooling system basically emptying itself into the oil pan.
Luckily I found out the block I pulled from the junkyard was actually a 2010 engine while I was swapping parts over from the original so it should be good to go. More than twice the mileage on the odometer when I pulled it but as long as it runs who cares at this point.
sumdewd
Jun 28, 2015 02:24 PM
hmt_eg
Feb 24, 2010 01:29 AM
finster
Dec 19, 2008 09:19 AM
integraboosted
Oct 13, 2007 09:20 PM
Paprika
Dec 10, 2004 10:24 PM
