AEM Fuel Rail and Regulator,what size is the inlet/outlet threads?
Ok,i'm trying to get AN hose ends for from my AEM Fuel Rail and Regulator but i dont know what size and pitch the threads are,are they 1/4" NPT? i was thinking of using Russel #612090 #06 Hose to 1/4" Pipe thread connector,do you think this will work? any help is much appeciated,thanks.
I remember seeing this info on AEM forums and dug it up for you:
The fuel rail is tapped on both sides with the same thread it is a 9/16-18 SAE thread which is also known as a -6AN.
Thanks,
AEM GN
There are three feeds to the universal fuel pressure regulator. two -6 and one 1/8 NPT which can also be used for a fuel pressure gauge. There is one return fitting which is -6.
Thanks,
AEM GN
Thanks,
AEM GN
Thanks,
AEM GN
Thanks,
AEM GN
Thanks,
AEM GN
Thanks,
AEM GN
Thanks,
AEM GN
[Modified by D-Man, 11:22 AM 11/15/2002]
It's not NPT then, it's AN. What that means is you need a -6an to -6an flare adapter. Just like with an Aeromotive or other regulator, the ports are tapped with -6an threads ....
The fitting will have the same threads on each side, but one is a male flare that you connect the line to. The other you would use an o-ring on and connect it to the fuel rail.
I went with one of these,i figure itll eliminate an extra fitting,think itll be alright
http://www.holley.com/HiOctn/ProdLin...HE/849006.html
[Modified by D-Man, 2:58 PM 11/21/2002]
sure will but itll take some time,alot of the stuff i ordered was on back-order,we should know by dec 1.
DA TeG 90
Jan 27, 2010 03:10 PM
