Turbo civic ek cold misfire issues
Hey guys, new to the forum, I have a 1996 civic sedan with a basic turbo kit, 8psi, d16y7 with y8 intake mani. T3 turbo. I’m having an issue where when it gets cold out, anywhere below say 5 degrees Celsius, my civic will only run on 3 cylinders until it is warmed up. I’ve been trying to figure out the issue for a while with no luck, I replaced cap, coil, plugs, plug wires, no luck. Any help would be appreciated.
that’s what I was thinking at first but I’ve always been running good 91 and I had the car tuned by one of the best tuners in my area, I may try to reach out to him as well and see if he knows anything but he’s hard to get a hold of
Pull the plug wires one by one while it's cold and missing until you find which one is doing it. Continue troubleshooting from there. Do a compression test.
Look at your temperature based fuel compensations - what are they set to (assuming you have a way to look at the tune)?
im not sure what program it is, I know it’s a chipped obd1 p06 , i bought it used and he hadn’t told me what the program was on it. As it’s also my first turbo car I’m not very familiar with the ecu/tuning portion
I built the car, I bought the ECU separate and was told it was chipped but the info on the chip was unknown, i then had the car tuned and he never told me what type of software he had used.
Use a laser thermometer and check each of the exhaust runners with it, it may tell you one if the runners (cylinders) is extra cold/hot and you may be able to narrow it down from there.
Thanks for the clarification on this. Now what injectors and map sensor are you running?
