Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Replaced camshaft sensor and cat converter won’t work
Old Jan 7, 2020 | 04:03 PM
Ryan Smith's Avatar
Default Replaced camshaft sensor and cat converter won’t work
HELP! 2002 Honda Civic 1.7 ex. While driving car suddenly popped a check engine light, car immediately wouldn’t run above 2000 rpm super sluggish. Exhaust manifold was cherry red. After about 20 minutes I could start the car and would work just fine. Until it happened again soon after. Suspected cat converter and replaced. Worked fine until about 30 minutes driving and same problem. Code was for a Top dead center sensor. Replaced that camshaft sensor after some research pointing to that. Struggled to start the car again but finally it started. Same problem still exists. There is a slight oil leak from the front of the engine as well (that’s been ongoing) What could be causing this?!
Old Jan 8, 2020 | 05:53 AM
NDNV's Avatar
Default Re: Replaced camshaft sensor and cat converter won’t work
Is the Check Engine Light on? What is the code?
Old May 6, 2020 | 11:07 AM
usdmes1's Avatar
That no running above 2000 rpm is called "limp mode". Not a very good thing if you are on the freeway or even on some city streets, because you cant accelerate like normal. I had the same problem, cat was red hot. I got it to a lighted parking lot, opened the hood, and sat there for 30 minutes waiting for a tow truck. But I was able to restart after things cooled down. Initially the TDC sensor was bad. Got it replaced and timing belt done at same time. Little did it know the camshaft sensor was going to get me in a few months. but I was low on funds anyways. Crankshaft is lower on timing cover and camshaft sensor, I replaced my self with a little help from youtube.So check both sensors and their respective wiring. Good luck.As for your oil leak, I would check your valve cover gasket, because when I researched the camshaft sensor, some referenced the valve cover gasket set.
mondiex
Oct 4, 2012 06:54 PM
Moderators Owned Me
Oct 5, 2006 02:12 PM
bma1818
11
Apr 20, 2006 02:11 PM
CWaldrop
Jan 10, 2006 07:02 PM
Crossett
Dec 24, 2001 07:08 PM
