Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Who is OE strut supplier for 2005 Civic D17A1?
Old Jan 2, 2020 | 02:21 PM
redturds's Avatar
Default Who is OE strut supplier for 2005 Civic D17A1?
My 2005 Civic Sedan 1.7 VP D17A1 with 108,000 miles has leaking rear struts and I've noticed that there are now rattling noises coming from back and its a bit bouncy.
I looked at the Honda labeled ones sold online at at dealer but they are about $98 each which seems a bit high to me for a cheap model Honda. I read that KYB makes the struts for most Hondas so looked at their part finder website which only appears to be Australian only domain: https://www.kyb.com.au/partfinder/
The list of struts shown under my ES1 comes back as D17A2 (vtec one) not my D17A1 (non vtec) car.
I am using regular standard everything, no tire, or wheel upgrades so am looking for something that will work that isn't junk. Does anyone know the manufacturer that made the rear struts for my model of Honda?
Old Jan 2, 2020 | 03:07 PM
em2 beater's Avatar
Default Re: Who is OE strut supplier for 2005 Civic D17A1?
KYB did. ES1 and ES2 uses the same struts. That's a mistake because ES2 is VTEC. You can buy KYBs pretty much anywhere, even Amazon.
Old Jan 3, 2020 | 10:03 AM
redturds's Avatar
Thanks. I found it now. https://www.kyb.com/catalog/
I'm gonna do some KYB rears then maybe change out the front with them later on. KYB appears to have slightly better ratings than Monroe and people say is a little bit firmer.
Old Jan 3, 2020 | 11:02 AM
aw614's Avatar
10 Year Member
Loved
The KYBs are ok for stock replacement, and they do their job, but I wasn't a fan of the rears on my brother's 02. For some reason the rear shocks with the stock springs sit a lot higher than the original suspension. Not sure why either and I was at my tech;'s shop watching him install the suspension and it was done the right way. (Had the 02 civic since it was brand new)
Haven't bothered to change it out since the car does the job as my brother's beater.
Old Jan 3, 2020 | 11:27 AM
redturds's Avatar
I hope it isn't too high. I don't want to have a jacked up rear end like some of those handicap vans have in the rear.
Old Jan 4, 2020 | 07:54 PM
aw614's Avatar
10 Year Member
Loved
This is how the 2002 sits, as you can see the rear sits an inch higher than I would like it and way more the stock shocks did. There are times I regret swapping it out b/c they were not blown and just the fronts were leaking.
Old Mar 26, 2020 | 10:17 PM
Pepe_Oros's Avatar
Try Tokico D-Spec; You might find for about $70 per pair (rears are cheappeer)
Best Regards
Use very same pieces You have installed
Best Regards
Mine is that Height as I use 215/70/15
Best Regards
File Type: pdf
createdtomove
Suspension & Brakes
Apr 24, 2018 06:43 PM
thehoj
Suspension & Brakes
Nov 16, 2011 04:57 PM
surr3a1
Sep 19, 2005 06:07 AM
d15civ
Mar 23, 2005 08:04 AM
oldskoolcivic
10
Jun 30, 2003 11:28 AM
