92 D16Z6 idle issue
Old Dec 21, 2019 | 07:01 PM
CpntKyro's Avatar
Default 92 D16Z6 idle issue
I’ve replaced the FITV and just replaced the IACV and did the “relearn procedure”, it drove just fine all day then when coming back home I got it up to 85 90mph slowed down nice and easy from those speeds and then pulled up to a stop and the idle dropped to a point where I didn’t think it was even on for a second, chugged through the intersection till it finally caught up and then clutched in and coasted into my driveway and before I could even touch the key it idled low and stalled out, now it just wants to idle so low that it almost kills itself.
Am I suppose to adjust some idle screw that I didn’t know about, this is the first “import” I’ve ever owned and worked on, I’ve only ever had carbureted chevys, so I’m kinda going in blind on this whole car and trying to learn, any help is much appreciated
Old Dec 22, 2019 | 08:57 AM
muellersfan's Avatar
Default Re: 92 D16Z6 idle issue
Old Dec 22, 2019 | 09:11 PM
Tortugax626's Avatar
Usually when I have any sort of idling issues, I address the coolant.. make sure it’s filled and burped out of all air in the system. That usually fixes it
Old Dec 23, 2019 | 04:41 PM
CpntKyro's Avatar
Originally Posted by muellersfan
I don’t have a tachometer or timing light to attach to it, would it be possible or safe to just do it while the engine is idling? Would a low idle also make it hard to get into first gear from a stop light/stop sign?
Old Dec 23, 2019 | 04:42 PM
CpntKyro's Avatar
sadly that’s not the problem I’ve messed with the coolant multiple times including burping the system and checking lvls
Old Dec 23, 2019 | 06:48 PM
Malt-liquor's Avatar
Clean and spray out IACV, clean throttle body, replace coolant sensor, bleed coolant with car jacked up, replace throttle body gasket, spray for vacuum leaks to name a few things.
Old Dec 26, 2019 | 06:26 AM
CpntKyro's Avatar
I’ve replaced the IACV and the EACV and bleed the coolant completely (even though I knew it was okay because it has a new radiator with fresh coolant) and checked for vacuum leaks. But I’ll try the throttle body gasket, and coolant sensor
Old Dec 26, 2019 | 06:28 AM
CpntKyro's Avatar
I also tried to adjust the idle screw and I can only back the screw out, like it’s bottomed out on the throttle body, I can only loosen the screw not tighten it, and when in loosened it, the engine didn’t idle any better. Do I just need a new throttle body?
Old Dec 26, 2019 | 07:18 AM
When engine is cold, do this:
1) With idle screw bottomed out, loosen screw one full turn counterclockwise.
2) Start engine.
3) Note cold-engine idle speed (rpm) on the cluster tachometer. Post number. Is idle speed steady or hunting?
4) Warm up engine by holding engine rpm at 3K rpm until cluster temp gauge needle points to ~middle on the gauge.
5) Note warm-engine idle speed (rpm) on the cluster tachometer. Post number. Is idle speed steady or hunting?
sweetbbyrays
Apr 11, 2012 07:28 PM
ShinyNewPenny
Mar 21, 2009 01:32 PM
racinmason85
Jan 19, 2008 09:15 PM
Joon Joon
24
Oct 26, 2004 07:06 AM
