99 civic B20V swap, Help
Hello Honda gurus, I just finished a B20V swap into a 99 ek hatch, when I start the car it turns on with no problems, but when I tap the gas, it stalls out. Or when left to idle, it will eventually stall out. Has new TPS sensor, distributor, wires, sparkplugs, fuel filter, fresh gas. Also, the RPM does not work. Running a SI Harness with jumper harness to a ship p28, advice or help is greatly appreciated
I thought the same thing, but when I check the wire colors, they are in the correct place. Also when I calibrated the TPS, is reading .58 v closed, and that is maxed out, meaning I cant turn it any more to get to .47 v
sigsr01
12
May 19, 2013 09:45 PM
go-fast_integra
11
Oct 21, 2010 04:35 PM
NINE TRE
Mar 28, 2005 10:34 PM
FLIPboi
Aug 29, 2002 07:16 PM
