Exhaust manifold 1998 civic CX hatch
Old Dec 20, 2019 | 05:38 PM
BossTofu's Avatar
Default Exhaust manifold 1998 civic CX hatch
my civic got the famous crack on the exhaust manifold.. can i just repair it like quiksteel for smog test.. i live in california.. CARB compliant cat is kinda expensive.. thats why im looking for a cheap fix to pass smog.. btw NO Check engine light present at the moment
Old Dec 20, 2019 | 05:53 PM
muellersfan's Avatar
Default Re: Exhaust manifold 1998 civic CX hatch
Does the product claim to be able to repair a cracked exhaust manifold? I could not find such a claim.
Old Dec 20, 2019 | 05:55 PM
BossTofu's Avatar
yes at the moment its doing fine.. its been there for a week now.. and still holding. lol
Old Dec 20, 2019 | 05:58 PM
After resetting the ECU, do any CEL codes pop up?
Old Dec 20, 2019 | 06:15 PM
BossTofu's Avatar
at the moment no CEL.. i have a pending code P1457 i change the shut off solenoid.. ill delete na code tom.. and use will observer for a few days if P1457 will go back.. then i have to do the drive cycle which is kinda time consuming
Old Dec 20, 2019 | 06:17 PM
BossTofu's Avatar
coz my plan is.. after i got pass smog.. planning to put yonaka exhaust and change the headers etc.. thats why im reluctant to buy CARB cat..
Old Dec 20, 2019 | 06:18 PM
P1457 is an EVAP system code. It has nothing to do with a cracked EM.
Prior to applying quiksteel, were other codes thrown?
Old Dec 20, 2019 | 06:19 PM
You won't pass emissions without a cat.
Old Dec 20, 2019 | 06:20 PM
BossTofu's Avatar
no other code.. yup maybe im thinking too much about the crack.. that will affect my smog test..
Old Dec 20, 2019 | 06:21 PM
Correct.
But if you get a hard P1457 code, then you won't pass the emissions test.
Old Dec 20, 2019 | 06:22 PM
BossTofu's Avatar
yup the cat delete plan is after i got pass the smog.. maybe ill try with this cracked / repaired manifold hopefully all will go well fingers crossed lol
Old Dec 20, 2019 | 06:23 PM
Do you plan to junk the car before the next emissions test?
BossTofu's Avatar
yup will observed if the code wont show up on my scanner again.. although it was only a pending not an actual CEL
Old Dec 20, 2019 | 06:25 PM
BossTofu's Avatar
nope.. its only 145k miles on it right now.. all stock.. so no plan of junking it
Old Dec 20, 2019 | 06:26 PM
You won't pass next year's emission test without a cat.
Old Dec 20, 2019 | 06:27 PM
BossTofu's Avatar
in my place we dont need smog every 2yrs.. i just need smog for change ownership..
Old Dec 20, 2019 | 07:29 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
I passed with mine filled with quick steel. Just be sure to follow the directions to a T and make sure you have your heat shield attached so it covers the repaired area.
Old Dec 22, 2019 | 01:34 PM
BossTofu's Avatar
thanks for the info.. yup quick steel is still holding.. i just need the evap monitor ready in my obd2 then ill go smog it.. will update after
jdm-love
Oct 2, 2019 03:43 PM
LordAphotic
Nov 18, 2010 03:43 PM
EK9_GRL
Northern California
24
Aug 5, 2009 07:36 PM
jb0705
Jul 6, 2009 07:53 AM
crazi_E
Mar 9, 2006 07:45 AM
