Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Electrical noise from 2002 civic lx
Old Dec 12, 2019 | 12:22 PM
mkkim's Avatar
Default Electrical noise from 2002 civic lx
So this weird buzz-electrical sound is coming even when the car's not started but accessories are on.
It's coming behind the glove box, I think. Where should I look for this noise to stop?
Old Dec 12, 2019 | 01:36 PM
leok99's Avatar
Default Re: Electrical noise from 2002 civic lx
Sounds like a bad relay.
Remove the glove box to check.
Old Dec 13, 2019 | 07:23 PM
mkkim's Avatar
Sound is now gone, after parking for 30 minutes. How serious is bad relay gonna affect driving? Should I repair this in shops or is this easy job for newbie DIY'er?
https://photos.app.goo.gl/EnzhRBkLrY83bZRR8
I took this video thinking it was coming from fan.
Old Dec 16, 2019 | 07:07 AM
benchwarmer's Avatar
5 Year Member
A relay is easy enough to replace , pop it out put one in . Are you replacing one needlessly ? If it's making noise or hot to the touch I'd replace it or even carry one on board , You can swap a similar one for another to see if it is the problem .
Old Dec 17, 2019 | 04:18 PM
mkkim's Avatar
I just pulled couple of relays from pick n pull (didn't knew I had to release the tab while removing.. so I broke 2 relays making them useless. Sorry world)
So full context for my car: DRL light is on until I turn low beam on (Canadian LX) but not actually functioning, switching to high beam from low beam also doesn't respond. No dash indicator.
Searching a bit more with this symptom led me to "DRL module solder" but since I didn't had soldering kit (and I was going to pick n pull anyways) I just pulled one out.
Could be the noise from DRL module's fault?
Old Dec 18, 2019 | 06:37 AM
NDNV's Avatar
Yes it can. When the DRL module goes bad they will buzz. Same with relays.
The DRL system uses the high beam circuit on low voltage.
Also after-market stereos can cause issues to various electrical components when you hook up the illumination harness of the headunit. Don't connect the illumination connection.
Old Dec 20, 2019 | 04:55 PM
mkkim's Avatar
Okay, I'll try to replace DRL module. Should I disconnect battery whilst doing this?
The car does have after-market radio/music player. Will that have any affect?
Old Dec 23, 2019 | 06:56 AM
NDNV's Avatar
Yes, it can. The illumination connection is not to be used when installing an after-market stereo in these cars. But I think you just have a bad relay on its way out behind the glovebox.
Metalmat
Feb 8, 2022 02:54 AM
MilanoLude
Jul 2, 2008 09:23 AM
97_hatch
Apr 1, 2008 06:10 AM
rega322
Jul 24, 2004 05:09 PM
pburke23
10
Apr 24, 2004 12:31 PM
