Transmission Fluid Leak
Old Dec 7, 2019 | 04:18 PM
andrewk99's Avatar
Default Transmission Fluid Leak
Good Evening,
I have developed what seems to be a slow transmission fluid leak on my 1996 honda civic DX.
It seems to be leaking around the transmission shift cable boot where it enters into the transmission.
My questions are:
-I'm assuming the gasket/boot for the shift cable has worn causing the leak??
-Does the fluid need to be drained in order to remove the bracket that the cable looks to be held in place by?
-Does the entire cable need replacing or can just the boot/seal be replaced?
Picture attached!
Ideas??
Thanks!
Old Dec 8, 2019 | 05:49 AM
muellersfan's Avatar
Default Re: Transmission Fluid Leak
The leak may be coming from the axle above the area shown.
Old Dec 8, 2019 | 12:22 PM
tony_2018's Avatar
Fish Twig
clean it up so you can better locate the leak.
Old Dec 9, 2019 | 11:17 AM
DaX's Avatar
DaX
Loved
Community Favorite
Originally Posted by andrewk99
-Does the fluid need to be drained in order to remove the bracket that the cable looks to be held in place by? No. The "bracket" only holds the end of the cable sleeve in place. It won't be leaking from there though. Remove the bolt holding the bracket in place and you'll see that the inner part of the cable connects to a small arm via a pin/cotter pin, and the shaft of that arm is what enters the transmission case.
Old Dec 9, 2019 | 06:07 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I have to agree at looking at the axle seal above. It looks like fluid is coming down from above. Not just from the cable access cover.
island_civic
Classic Hondas
Jul 22, 2008 06:50 PM
Booz
Mar 25, 2007 06:27 PM
VTECth1s
Aug 19, 2006 09:39 AM
Digitalcivic
May 1, 2006 09:14 PM
return_2020
Dec 8, 2004 02:38 PM
