EG dash illumination lights not working
1) Buy a multimeter if you don't have one.
2) Unplug the cluster connectors.
3) Check whether all Red/Blk wires (there are multiple) from fuse 19 have battery voltage with the parking lights turned on.
4) If the Red/Blk wires have battery voltage, test whether the Red wires (there are multiple) that run to the dimmer switch have good ground.
The tests above will pinpoint the problem.
imptricer
13
Nov 22, 2012 07:47 PM
