CRV AWD B20/VTEC Stock engine turbo upgrade to 400whp. What direction to go with?
Old Dec 5, 2019 | 11:40 AM
Rogue964's Avatar
Default CRV AWD B20/VTEC Stock engine turbo upgrade to 400whp. What direction to go with?
I just bought a 2020 Explorer ST that I daily drive and wanna play with my 99 CRV Manual 4WD. What I am looking for is something that is fun to drive on the streets, reliable, and something that spools up fast (sub-3500rpm?) and something I don't have to rev 8000+ rpm everytime I wanna get my jollys off... Ideally, a super fat mid-range usable powerband and 300-400whp on 93 octane / and or E85.
What I have so far:
- B20 shortblock (stock rods & pistons)
- ARP Rod Bolts & Head Studs
- B20vtec Conv Kit
- P72 GS-R Cyl Head
I have done a little browsing over the last two nights at turbos. I was suggested to look at the Precision 5558 Gen2? Anyone have any experience with this turbo in a similar setup? Would there be a better turbo you'd suggest for my expectations? -- Thanks!
Old Dec 5, 2019 | 12:03 PM
Chance EG's Avatar
Default re: CRV AWD B20/VTEC Stock engine turbo upgrade to 400whp. What direction to go with?
Look into the Garrett T3/T4 50 trim as a potential turbo candidate.
May want to consider upgrading the rods to an H beam since you're going to be making most of your torque down low.
Don't forget the added weight of your vehicle as well as the 4WD/AWD is actually going to make the turbo spool even faster down low, since there's more load on the engine/exhaust pressure trying to move the beast.
Old Dec 5, 2019 | 12:10 PM
Rogue964's Avatar
Thanks!
Hotside preference? 48,63?? 82 seems like it would be more high rpm powerband?
Old Dec 5, 2019 | 02:36 PM
Chance EG's Avatar
Default Re: CRV turbo upgrade suggestions
Originally Posted by Rogue964
Thanks!
Stay with .63
.48 will be way too small for your 2.0L, especially if you fit a VTEC head which flows better.
.82 on the other end of the spectrum would be too large to be optimal for this build, and for the turbo you have in mind, and for the intent you have for the car.
Old Dec 6, 2019 | 02:06 PM
TheShodan's Avatar
Moderator
Stay with .63
Depending upon exhaust wheel and profile, of course.
Old Dec 7, 2019 | 12:16 AM
Chance EG's Avatar
Of course. I was assuming we were talking about one of the aforementioned turbos.
clemsonteg
Nov 13, 2016 05:44 AM
steveDC2
Aug 20, 2010 07:36 PM
g2tegsown
Aug 24, 2007 11:43 AM
EJ8boosted
Dec 23, 2005 07:49 PM
builtB20turbo
Oct 12, 2003 06:23 PM
