No start condition
My 1996 honda accord 25th anniversary, I feel like ive done alot to this car already but the problem is, when I turn the key it would start just fine 1 day the car would turn over start and then die. So if I put starter fuild on my air filter or intake manifold it starts right up.. I know my timing is off a little bit but was running fine. Main relay is good spark plugs were over with oil, fuel pump pressure fine fuel to injectors, fuses good, battery good . Clean idle control valve it's good cleaned injectors , car started up after I cleaned it then died due to clogged fuel filter replaced that now wont start.. any ideas
Nov 17, 2012 07:52 AM
Beegee208080
24
Jun 3, 2012 06:53 PM
vanisher
11
Oct 15, 2007 07:00 AM
