DOH!!! Forgot to reinstall the washer between the torque converter and flexplate...
Old Nov 29, 2019 | 08:54 AM
notnilc20's Avatar
Default DOH!!! Forgot to reinstall the washer between the torque converter and flexplate...
I'm guessing its an implrtant piece otherwise it wouldnt be there....but looking at the diagram I cant see what it does. Could someone enlighten me?
Old Nov 29, 2019 | 04:05 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: DOH!!! Forgot to reinstall the washer between the torque converter and flexplate.
I would assume it spaces out the torque converter or it helps keep things aligned if there is a recess for it.
Old Nov 29, 2019 | 08:55 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I recall the automatic bolts are shorter than the manual bolts. Thinking about that a bit. I suspect the extra ring with the flex plate may be a spacer for the shorter bolts to prevent them from bottoming out and giving a false torque when tightening.
If this is the case, your main 12 point flex plate bolts may loosen up over time causing you grief and possible damage to the flex plate.
Old Nov 29, 2019 | 09:47 PM
notnilc20's Avatar
Thanks for the replies....I went ahead and reinstalled the washer just in case. What a bummer though, I was literally about to put fluids back in the car when I found the thing hiding under the exhaust manifold heat shield. Had to take evrything back apart, axles, shifter cable, yada yada...anyway, it's done now. thanks a lot.
Old Dec 1, 2019 | 05:50 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Rough, but better to know you did it the right way, rather than worry!
Jdmdelsolb16a
Engine Management and Tuning
May 11, 2011 06:11 PM
:::SIRll_EJ1:::
Sep 2, 2009 03:05 AM
xbB
11
Sep 26, 2004 12:50 PM
notsure
Jun 18, 2004 10:57 PM
bruthaboost
Jan 12, 2002 02:54 PM
