Did I damage/ruin my transmission?
Old Nov 27, 2019 | 04:55 AM
Valkyria90's Avatar
Default Did I damage/ruin my transmission?
I'm sitting at work right now, anxious that I might have damaged my manual transmission on my commute here. I drove like normal and when I needed to downshift to first gear to get into a roundabout right before going onto the highway.
For some reason the shifter would not go into first gear, and I quickly just put it into second gear and had enough speed to clear the roundabout.
When I was cruising in about 80km/h I was curious what had just happened so I pressed down the clutch and tested every gear from 5th down to 1st. Every gear was smooth, but the first gear was still stuck. I tried giving it a bit more force to get it in gear and heard a grinding noise that could banish demons from the gears. I swear I also felt a slightly burned smell immediatly afterwards.
I put it back into 5th and got to my workplace where I knew I would need to downshift again at some point. When I got to a place I needed 1st gear to drive on, I once again tried to get into gear, and this time it succeeded. It was slightly harder to get into 1st the first time I tried, but afterwards it seemed to shift normally through all the gears.
I'm obviously not looking forward to my drive home, and I am curious what may have caused the stuck gear in the first place. I don't know when the tranny fluid was last changed, but could bad fluid be the reason for this issue, and a fluid change prevent it from happening in the future?
And what was the burned smell I could smell when I grinded the gears on the highway?
Car is a 94 Del Sol with 190.000KM on the meter.
Thank you for any advice.
Old Nov 27, 2019 | 05:26 AM
tony_2018's Avatar
Fish Twig
Default Re: Did I damage/ruin my transmission?
You forced it into 1st gear while in motion? wow, hope it was worth it.
Old Nov 27, 2019 | 06:35 AM
NukeNinja's Avatar
Curious if you were able to shift into reverse at 80 km/hr?
Old Nov 27, 2019 | 07:49 AM
mk378's Avatar
If you're saying the gears grind when you try to shift to reverse with the car stopped, that is a clutch problem first thing to check there is the clutch fluid level.
Old Nov 27, 2019 | 10:30 AM
Chance EG's Avatar
Synchros are fried.
Have a shop tear apart the christmas trees, and replace the synchros, bearings, and rings.
Huberts5-lugBB1
Mar 18, 2018 04:22 PM
.paul
Jan 12, 2007 12:35 PM
wrx'n you
Dec 21, 2005 08:20 AM
nemesisSI
13
Apr 11, 2005 01:09 PM
elevatethis
41
Nov 24, 2003 12:02 AM
