Transmission & Drivetrain Gearboxes, Differentials, Clutches
Transmission Swap?
Old Nov 24, 2019 | 11:22 AM
SaltyBeaR25's Avatar
Default Transmission Swap?
Hey guys,
I wanting to try to get some information on something here, I looking into getting a 98 Honda Civic Sedan DX with a D16 5 speed (don’t know if its Y5 ,Y7 ,Y8 or A2 model), I’m wanting to put a Ej7 HX 5 speed in it for better gas mileage. Will it bolt up without any modifications need?
P.S
Future build for high pulls with turbocharged system if this helps.
Old Nov 24, 2019 | 04:00 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: Transmission Swap?
It’s a y7 engine.
the transmission you can change, but it’s counterintuitive to do so if you’re planning on turboing it.
just keep your foot off the skinny pedal and you’ll get decent mpg.
Old Nov 25, 2019 | 07:15 AM
Lol I’ll keep the pedal at a decent level lol..but how would it be counterproductive in I run turbo set in the long run...I thought more final gear the better for high top speed as long you have the power to pull the gears?
Old Nov 25, 2019 | 02:30 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
Unless you're doing land speed racing, you want shorter gears.
Old Nov 26, 2019 | 07:35 AM
No dead stops, and anything like that I’ll be doing speed runs from like 65mph or 55mph, so I would think the 3.72 final gear would be great especially with a turbo set up?
Old Nov 26, 2019 | 12:59 PM
DaX's Avatar
DaX
Loved
Community Favorite
No, it won't. It will load up and cause the turbo to spool, but you'll be putting unnecessary strain on the drive train running high boost at low RPM. Just stick with the DX transmission if you want "long" gears with a turbo.
Now, if you're hypermiling, the VX or HX transmission will work OK for that, but be prepared to downshift a LOT if there are any hills where you live. You will likely need to use other driving techniques as well to maximize your mileage.
SaltyBeaR25
10
Nov 28, 2019 08:37 PM
99CoupeEK
Feb 21, 2019 10:45 AM
thatRobguy
Jan 10, 2015 09:18 AM
skier
10
May 21, 2013 05:57 PM
hikerauto
Aug 28, 2004 08:01 AM
