Most reliable/daily driveable magical path to 200whp?
Old Nov 14, 2002 | 10:06 PM
io_burn's Avatar
New User
Default Most reliable/daily driveable magical path to 200whp?
It seems for an all-motor setup, 200whp is the magic number for the R (Or, at least from what I've gathered from various posts). Is it possible to hit 200whp while at the still time having a reliable daily driver? I'm under the impression that Skunk Stage1's or Toda A's really kick the **** out of your engine after a while. I'm trying to plan out what I want to do with the R... 200 seems like a good number to shoot for.
What is involved in building up the engine to 200whp? Reliability really is paramount, it's what I love about Honda's so much. If squeezing a little extra juice out of the engine is going to **** that up, then nuts to it. Otherwise what do you guys think? Cams, header, exhaust, cat, higher compression... that puts you pretty close to 200whp, no?
The R currently has an AEM and CAI on it, which I have the understanding are two good things to start out with... Any advice and/or dollar amounts would be appreciated
Old Nov 14, 2002 | 10:29 PM
nEoMuGen's Avatar
Default Re: Most reliable/daily driveable magical path to 200whp? (io_burn)
Go Hytech all around. Properly dyno tuned Toda B's....and you are at it.
Old Nov 14, 2002 | 11:27 PM
MK Ultra's Avatar
I think hp is nothing more than an insignificant number by itself.
Why is 200 whp the number you wish to have? What do you want the car to do?
It is entirely possible to have a reliable, daily drivable, 200 whp motor. It is also possible to have a poorly-running 200 whp hand grenade.
Old Nov 15, 2002 | 01:18 AM
Rob Dizzle's Avatar
Default Re: Most reliable/daily driveable magical path to 200whp? (MK Ultra)
hytech/smsp header
high 11 compression
stock 00+ R cams
maybe some port & polish headwork
light flywheel and lighter wheels
along with some dyno tune time using hondata or other flavor
Old Nov 15, 2002 | 02:13 AM
rainmanEK's Avatar
big strong guy
Default Re: Most reliable/daily driveable magical path to 200whp? (Bob-DC2)
over bore, 84mm +
good luck, eric
Old Nov 15, 2002 | 04:36 AM
MPH's Avatar
MPH
New User
I have 200whp with skunk 1's and it's super reliable. I daily drive my car through rush hour DC/Va traffic alot and I have 200 on tap. Why wouldn't it be reliable with stage 1's or Toda A's? Specs are close to stock cams.
Old Nov 15, 2002 | 04:53 AM
Doctor CorteZ's Avatar
hytech/smsp header
high 11 compression
stock 00+ R cams
yep yep.
totally factory reliable....
Old Nov 15, 2002 | 07:16 AM
dohcsideSi's Avatar
low expectations 200 is nothing for an R and easily attainable w/ a stock bottom end and a pair of mild cams (i.e. -skunk 2 stage 1)...tuned of course
Old Nov 15, 2002 | 07:20 AM
RTW DC2R's Avatar
Default Re: Most reliable/daily driveable magical path to 200whp? (dohcsideSi)
nawwwwwwwz
Old Nov 15, 2002 | 07:23 AM
Cosworth's Avatar
IMHO, just do all the bolt-on's and some tuning and you're @ ~180whp. That's more than enough for a daily driver and not have to worry about rigorous maintenance schedule.
My picks:
I: Mugen CAI
H: Toda 4-2-1
C: Carsound 54000 series
E: Mugen Twinloop
ECU: Kenji P28
Piggyback: V-AFC (or Hondata if you have tuner near by)
Even without messing w/ camgears, fuel pressure, etc... the above should get you very close to 180whp, if not slightly over.
W/ 180whp, just add Toda fly & clutch + JDM 4.785, then that's more than enough for any application.
Old Nov 15, 2002 | 07:52 AM
MPH's Avatar
MPH
New User
Easily attainable..... How many do you know of?
Old Nov 15, 2002 | 08:35 AM
DarthLuder's Avatar
New User
If you can get 200hp out of stock cams that would be your most reliable set-up.
Old Nov 15, 2002 | 08:38 AM
io_burn's Avatar
New User
Default Re: Most reliable/daily driveable magical path to 200whp? (ITR GURU)
Hmm... So this will cost me around 2-4 grand for 200whp? I found a website last night that said a stock ITR with a AEM CAI has 170hp at the wheels, does that sound right?
Old Nov 15, 2002 | 08:53 AM
vtec.dc2's Avatar
370cc injectors-hondata (310cc should do the job too), icebox, jdm4-1 header, 63.5mm cat&exhaust, - i was at 176whp
then, added 8.5 lb flywheel
head port-n-polish, cam gears (maybe some stage 1 camshafts), toda header
with good tuner and good tuning system and best header you should be able to hit 200whp on stock or stage 1 cams. you could first see what you can do on stock cams, and then try stage 1 (toda,skunk, whatever)
(theres also test pipe, power steering that could be added to above)
it could cost thousands for me to do these upgrades, and the reason i chose to make more hp.
[Modified by vtec.dc2, 12:55 PM 11/15/2002]
Old Nov 15, 2002 | 09:05 AM
skunked's Avatar
Default Re: Most reliable/daily driveable magical path to 200whp? (MPH)
I agree, I also have 200whp on Skunk Stage 1's in a B18C1. Daily Driver with no problems
Old Nov 15, 2002 | 09:06 AM
sneakychaos's Avatar
Default Re: Most reliable/daily driveable magical path to 200whp? (skunked)
Or you could just trade your car in on a car that has 200HP from the factory. Thats pretty reliable. w00t
Old Nov 15, 2002 | 11:30 AM
dohcsideSi's Avatar
b18c1 and c5's.....about 10-15....200 is just a number...now 240-250whp your talking some serious work and a little less reliabilty....
Old Nov 15, 2002 | 11:38 AM
MPH's Avatar
MPH
New User
10-15 over 200whp with the stock bottom end...damn. I can see an overbored 1.8 motor making well over 200 but a 1.8?
Old Nov 15, 2002 | 11:43 AM
zer0zer0 TypeR's Avatar
is it possible to achieve 200whp with stock internals? i have the basic bolt on's and hondata stage 3 and i'm almost at 180whp. i can imagine it would be very difficult to be near 200whp without more aggressive cams.
Old Nov 15, 2002 | 11:57 AM
MPH's Avatar
MPH
New User
Default Re: Most reliable/daily driveable magical path to 200whp? (zer0zer0 TypeR)
Yes it's possible but hard in a 1.8. Bore it out to 2.0 and you can probably do it with R cams. I had 197 with bolt ons and valvetrain with hardly any tuning with Skunk stage 2's. It's possible but the curve sucked compared to my stage 1's. I don't see it as "easily attainable".
[Modified by MPH, 3:58 PM 11/15/2002]
Old Nov 19, 2002 | 05:12 AM
dohcsideSi's Avatar
"is it possible to achieve 200whp with stock internals?". I don't see it as "easily attainable".
i'm looking for 250ish whp so i might have a slighlty different idea of "easily attainable"
h46it
17
Nov 8, 2007 02:09 PM
DFWRSXS
17
Dec 21, 2005 02:45 PM
Haleiwa-Brando
Nov 26, 2005 08:56 AM
Cynical 1
Oct 2, 2002 02:31 PM
Ross
Dec 4, 2001 05:38 PM
