Lsvtec Piston cam set up
I have a b1 block with p72 head, ls crank with scat hbeam rods and gsr p72 pistons 81.5mm, im wanting to go all motor stage 3 cams but i dont know which type of stage 3 cam to go for, the lift is what im confused about. How do i match comp w piston to cam, or am i talking out of my *** and just get a stage 3 coming
For a stage 3 to be fully optimized, most CAM companies recommend a fully built head w/valve train upgrade. You can get away with a stage 2 cam with just upgraded springs and retainers. But since you're going to be stock, your best bet is ITR/CTR cams. Once you boost, upgrade the valve train and go with the stage 3 cam. For now, build the bottom end, upgrade the springs and retainers and you'll be able to rev out to 8K no problem (provided you have ARP rod bolts and head studs).
b18sihatch
Jun 16, 2006 09:59 AM
GSR4U2NV
14
May 25, 2005 04:16 PM
