Battery Drains
Old Nov 13, 2019 | 01:49 PM
Bobkendi's Avatar
Default Battery Drains
My 2017 Accord Sedan is draining .91A with the engine off and nothing I can see on (car not in Accessory mode). Is this normal?
Old Nov 13, 2019 | 04:02 PM
~sp33~'s Avatar
EFB055
Default Re: Battery Drains
Probably be more helpful to post it on the right forum.
At a guess, does the car have a courtesy / follow me home / interior lighting that remains on timer after the key is removed? Modern cars have systems that continue to run for periods of time after the engine is shut off.
Is your battery dying? or did you just measure it and are uncertain if it's normal?
Old Nov 14, 2019 | 03:13 AM
Bobkendi's Avatar
Sorry I mis-posted on this forum. Battery was dead yesterday. But I also wondered if .91A bleed was in spec. Interior lights do stay on briefly but do go out after a few minutes.
Old Nov 14, 2019 | 11:31 AM
Tyson's Avatar
regardless of the car, a 1amp draw is obviously too much.
typical troubleshooting tactic is to measure across individual fuses to see which system is causing the issue and go from there.
on a 2017 car, that should be a warranty issue, let the dealer figure it out.
Old Nov 15, 2019 | 09:23 AM
Bobkendi's Avatar
Old Nov 15, 2019 | 09:25 AM
Bobkendi's Avatar
Took it to Honda dealer. They replaced the battery ($167) and said there was no battery bleed. We’ll see.
Old Nov 16, 2019 | 02:44 PM
honda90civicsi's Avatar
Hope this works out for you. Will be interested to hear back, if that took care of the problem. Honda dealer, huh? Haven't used one of those in a very long time, since there's so many more reasonably priced independent shops with Honda as a specialty.
Old Nov 20, 2019 | 01:13 PM
Bobkendi's Avatar
All's well so far. The reason I used a dealer was the car is still in warranty.
Onismurai
Honda Accord 2018- Current
Feb 28, 2019 10:44 AM
teddy_dc2
Feb 16, 2017 06:28 AM
lizp
Jan 3, 2011 04:36 PM
sky88
Jul 20, 2004 08:57 AM
Project X
Feb 24, 2004 05:44 AM
