B18b1+C1 head
Building a lsvtec, did all my research but couldnt find what i was looking for. What low compr pistons fit best with the set up? Also whats the best bore size? Im thinking 81.5 but will that mess with compression? 10.1:1 the goal
Ok, but that still doesn't tell me anything. Are you planning on staying N/A or going Boost/Forced Induction? Are you looking for reliable daily or weekend warrior? Aside from LSVTEC, what is your goal with the build?
Alright then. Well, to answer your question, if you overbore to 81.5mm (won't mess with comp) and go with a decent set of 10.1:1 comp pistons and decent rods, new bearings, TypeR Oil Pump, new water pump, etc. You should have a solid build on your hands. If you stay N/A, the LS trans will suck. If you go boost, it'll be fine.
