Physical slop in steering column sleeve.
Old Nov 3, 2019 | 06:12 AM
B_Swapped93's Avatar
Default Physical slop in steering column sleeve.
I have a few cms of slop where the larger part of the steering column goes over the narrower portion(see pic). The car has NO bump steer and feels fine on the st even even on hard turns but this slop concerns me. The slop is felt in the steering itself and is not simply right or left but up and down and even in and out. Yes the 4 bolts that clamp the column are tight with blue loctite and the steering wheel nut was just torqued and loc-tited. I can push up on the smaller portion of the shaft and it's very noticeable where it slides into the larger part it wiggles close to upwards of 3/32nd"
Old Nov 3, 2019 | 02:51 PM
tony_2018's Avatar
Fish Twig
Default Re: Physical slop in steering column sleeve.
You'll need the completed piece of what you're pointing at.
Old Nov 4, 2019 | 08:43 AM
Can't be purchased separately i'd need to buy the entire Column from Honda.
Old Nov 4, 2019 | 03:09 PM
tony_2018's Avatar
Fish Twig
junkyard if you can.
RanCRX
10
Oct 9, 2007 05:44 PM
breanna
Feb 28, 2006 12:51 AM
choi830
Oct 30, 2003 05:13 AM
kliph
May 27, 2003 09:42 AM
