Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
How Remove Pistons D17A2 Engine Block in car?
Old Nov 1, 2019 | 04:22 AM
lindylex's Avatar
10 Year Member
Default How Remove Pistons D17A2 Engine Block in car?
I have a 2003 Honda EX 5 D17A2 I am trying to remove the pistons from under the car. I removed the oil pickup strainer. The oil pickup strainer is attached to I believe is the engine girdle? Please correct me here. I need to remove that so I can see easier the bottom of the pistons so I can remove them? Does this make sense? I removed the very long bolts but not sure if this part needs to be removed. It does not budge and I am not sure if this is the correct procedure to remove the piston while the engine block is still in the car.
The cylinder head is already off and I want to push the piston out from under.
What are the torque specs for these long bolts and the oil pickup strainer?
Thanks
Old Nov 1, 2019 | 08:58 AM
lindylex's Avatar
10 Year Member
Default Re: How Remove Pistons D17A2 Engine Block in car?
Never mind I got the piston. I need the torque specs for the piston nuts and bolts that hold the bottom of the engine crankshaft. I am not sure what it is called. The oil pickup filter is screwed into it.
gducatte
Aug 22, 2018 09:23 AM
PariahBoardshop
Jan 20, 2010 07:37 PM
jyracer
Jan 13, 2009 08:16 PM
kingofnothing
14
Jan 6, 2009 03:08 PM
Aeka GSR
May 31, 2002 04:47 PM
