94 ex isnt starting ... any ideas ?
Old Oct 29, 2019 | 05:54 AM
Accord+1994's Avatar
Default 94 ex isnt starting ... any ideas ?
hi everyone I'm new to the page so idk how this works on getting help
my car isn't turning on it isn't turning over either idk what it can be
I had the car for about 4 years now I maintained it the best I could
I have replaced the motor oil (castrol gtx high mileage 5w30) my car has 280xxx
I have replaced the oil filter (oem honda filter)
I have replaced the spark plugs (NGK)
They car also got a 50/50 radiator flush (Prestone)
^ I replaced months ago way before this issue I have now ^
I have replaced the spark plugs wires with some brand that I could find at the time (BREMIUM 7mm)
^ I replace it about a year ago ^
I have bought a new battery on November of 2018
thinking it was the starter I went and I also bought a new starter because the old one went bad and still isn't doing anything
all fuses are good and I think the main relay is good to idk how to check if its any good so I have 2 of the main relays and swapped them and with both of them it does the same thing and I opened them and they look good not burnt or anything but im not sure which is the main relay im assuming is the grey small box under the dash
the cluster temp and gas gauge had stopped working so I bought new both ECT UNIT SENSOR and the ECT SENSOR (both oem honda) because I thought that is why but still nothing but I noticed the RPM gauge wasn't working either and when I turn the key to turn the car on the Drive light will turn on with the cluster and turn off right after and the parking light turns on with the old cluster
so I figured it might be the whole cluster so I bought one used because I cant afford a new one the one I just purchased its from and LX not from EX idk if it makes any differnce now the mph gauge when I put the switch on jumps to 20
after all of this the car isn't turning on at all just doesn't do anything I turn the key and all the lights on the dash turn on as they should including the radio I hear a click noise coming from like the middle of the dash right now I have the cover that is on the dash that has the temperature control unit with the vents off bc I removed it to get to the cluster well from in there I hear a clicking noise and idk what that means
oh the check engine code the comes up is 2 long blinks and 2 fast blinks after
anyone has any ideas ?! can someone give me some ideas on it please lmk thanx
Accord+1994
Oct 30, 2019 03:10 PM
92da9rabi
Apr 24, 2011 06:25 PM
dustyb20
Mar 11, 2009 03:09 PM
pjean_07
Jul 26, 2008 11:11 AM
91hatchcivic
Lighting
Apr 14, 2008 11:16 AM
