Two 90deg. on top coolant hose?
Old Oct 28, 2019 | 01:11 AM
Raf99's Avatar
Default Two 90deg. on top coolant hose?
Anyone have any experience to know if this will work? I won't bore ya'll with the long story and the prior several attempts (which all kink or do not allow proper flow). The two 90s is the only way I can get this to work currently but have not tested it. Anyone see any issues?
Old Oct 28, 2019 | 06:59 AM
maxwellmercer's Avatar
Default Re: Two 90deg. on top coolant hose?
Why not 2 straights and a short piece of hose?
Old Oct 28, 2019 | 01:35 PM
Raf99's Avatar
No way it will work. I've tried 4 different ways now and just not possible. The block is lower than the rad, they are also off angle. With two 16AN fittings (on block and on rad) it only leaves a very short piece of 16AN hose which will not bend to what you need it to. You end up with a kink in the hose. This is the final edition, just looking for input on if this will restrict coolant flow too much.
thanks
Old Oct 28, 2019 | 06:57 PM
B00STD's Avatar
5 Year Member
Loved
Community Favorite
Should work fine...
Old Oct 29, 2019 | 12:35 AM
Raf99's Avatar
Originally Posted by B00STD
Should work fine...
Thanks
Old Oct 29, 2019 | 09:23 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
It will work just fine... and this routing/design will not stretch/bind during engine movement within the engine bay. Send it.
Old Oct 30, 2019 | 12:42 AM
Raf99's Avatar
Agreed, thanks! Tested it last night and it is functional.
Old Oct 30, 2019 | 06:58 AM
FormerMember's Avatar
nice work the location is perfect your away from the headers which can generate heat and you have good flex for engine movement spot on
Old Oct 30, 2019 | 02:05 PM
Raf99's Avatar
Never thought of that, thanks.
Old Nov 4, 2019 | 03:35 PM
Raf99's Avatar
FYI, did road test this and was a steady 190 max under load.
Old Nov 6, 2019 | 10:23 AM
that's awesome so your good to go
Jackson Neal
May 31, 2018 05:25 PM
imbest123
10
Dec 8, 2010 08:15 AM
Jibin
Apr 24, 2010 07:42 PM
MenaceL.A.671
Sep 14, 2005 04:36 AM
92SleeperH23
Sep 2, 2005 05:55 PM
