Integra keeps popping both 15amp acc ign fuse
So my 96 b20vtec integra keeps popping fuses 15a under dashboard as soon as I turn the key to on position, the car literally left me stranded
I have a 255 walbro fuel pump which I upgraded ground to 10 gauge and power from battery to 10 gauge with 30 amp relay (which pops also) and I have 410cc injectors the denso stock ones for rdx I have a chipped p28 I have a check engine light srs and abs but when I try to check the check engine light it doesn’t beep please help???
Can I just put a wire from battery to that pin spot where black/yellow is burnt or should I just jump it by using the same color and loop it??
rudyndrew
Jan 3, 2011 03:00 PM
62maxx
Oct 25, 2006 03:45 PM
