Honda Ruckus and Scooters Ruckus, Silverwing, Reflex, Helix, Metropolitan
Need Starter Help 2013 Ruckus
Old Oct 18, 2019 | 02:30 AM
Keaton Romeiser's Avatar
Default Need Starter Help 2013 Ruckus
So I bought a 2013 Ruckus that had been sitting for a year after it died abruptly. I’ve changed out the gas and the oil, fixed the fuel pump, put in a brand new battery. Went to check if I had spark but the spark plug connector head came off. Jimmy rigged that to work and still no spark. Currently have the carb soaking in gas after using carb cleaner and we’ll see if that helps.
update: when I turn the key, fuel pump works, but no engine sound what-so-ever. HELP
Old Oct 18, 2019 | 06:14 AM
rchid's Avatar
Default Re: Need Starter Help 2013 Ruckus
I'm having the same problem. I've replaced the following with no luck still.... maybe something on this list will help you out.
  • ignition coil
  • brake switches (both sides)
  • Stator
  • fuel filter
  • wire harness
  • spark plug
  • ignition sub harness
IDK what is going on but i'm not getting any spark to the plug. The only other thing I can think of replacing is the bystarter which is connected to the carburetor, but I know that has nothing to do with getting spark to the spark plug.
I do know that you have to get power through the stator before spark is made. Maybe you can use the kick start method to get the engine cranked over and get the stator moving.
Old Dec 20, 2019 | 03:27 PM
CodyB83's Avatar
Swap ecm's with someone if you can for testing.
Old Jan 7, 2020 | 05:26 PM
rchid's Avatar
did this ever get fixed?
boostfever
Jul 8, 2009 04:11 PM
97civicgc
Jan 28, 2009 01:22 PM
Red1ine
Apr 2, 2008 07:52 AM
jojo69
Nov 1, 2006 04:38 PM
Kappa1
Nov 25, 2003 01:14 PM
