Turboedit questions?
So i have a 1991 honda civic si with a d16, that i will be putting a turbo on and 550cc injectors, and a 340lph high performance fuel pump. Was wondering where i should start with turbo edit? Like i am going to chip my obd0 ecu cause it is a pm6 which everyone says you can chip. So can i find base maps online, or can i have someone send me a base map or a normal tune. I am not looking for 400hp here. Just low hp gains, just want the car to not blow up in two days? I don't see an option on chrome for obd0 so i can't use that right? If someone can help me out that would be awesome thanks.
This is a stock d16a8 bin file i loaded off my pm6 ecu, i am planning on going turbo as well but converting to obd1 to get live tuning through hondata. this way you dont have to unplug the chip, read the chip, make changes, burn the chip then plug it back into the ecu for every minor change you want to make
Correct you cannot use Crome in an OBD0 setup. Your going to have to run the NGxx bin file. I’m not sure what it last went up to as you will have to browse the PGMFI forums. I was a big advocate of Turboedit back in the day but honestly nowadays I would splurge for an OBD1 dizzy and ecu and go that route. Just much easier and better options if you ask me. IF you are determined for turboedit than yes you can make it work by all means.
