differences in b18c1 and b18c5
Old Nov 14, 2002 | 07:42 PM
redteg1's Avatar
Default differences in b18c1 and b18c5
are the only differences found in the head? the block is the same correct? besides the engine codes etched on the block. is the crank on the itr different?
Old Nov 14, 2002 | 07:49 PM
Q-OnE's Avatar
Default Re: differences in b18c1 and b18c5 (redteg1)
i thought someone just brought the same topic up like 5 days ago. you try searching yet?
Old Nov 14, 2002 | 08:11 PM
rodimus's Avatar
Default Re: differences in b18c1 and b18c5 (NAgs-R)
alotta damn differences. different head, intake manifold, block is even different, crank is different *type r has 8 counterweights, gsr has like 4* pitons, rods different...list still goes on..
depending on what you're doing you might want the gsr over the r engine.
Old Nov 14, 2002 | 08:13 PM
Ferrell's Avatar
Default Re: differences in b18c1 and b18c5 (EVOL)
welll, imagine that, https://honda-tech.com/zerothread?id=261965
took a whole 20 seconds to find this... im sure there are plenty more threads on here.
skafia's Avatar
25 Year Member
Default Re: differences in b18c1 and b18c5 (Ferrell)
You guys are a bunch of jackasses.
Old Nov 14, 2002 | 08:23 PM
B2FiNiTY's Avatar
Default Re: differences in b18c1 and b18c5 (skafia)
At least they are helping
Old Nov 14, 2002 | 09:09 PM
4-1-1's Avatar
Default Re: differences in b18c1 and b18c5 (B2FiNiTY)
http://12.239.16.150/specifications.html
Old Nov 14, 2002 | 11:52 PM
00 FBP ItR's Avatar
The block is not different.. the block is a gsr block p72 stamped b18c5 its only the internals that are upgraded.. but the bare block itself is a gsr block..
If you doubt what i'm saying then check the REAR of any c5 block and you can see that its stamped p72 in the back.
just FYI.
dcfreak
Aug 21, 2007 12:52 PM
95BG33PGSR
Feb 15, 2006 07:30 AM
ITRPNP
Jan 30, 2006 06:15 AM
RAS Motorsports
Oct 19, 2004 02:05 PM
Vampyre
Apr 6, 2003 06:17 AM
