Idle and throttle issue
When accelerating it starts to splutter and slug until getting close to vtec, I've narrowed it down to the o2 sensor, when it's unplugged and the engine light pops up it runs fine with no issues.
However, I brought a brand new o2 sensor and put it in and the same issue occurred and I tried another o2 sensor off the same motor. Whenever it is plugged in starting the car after awhile it drops down to near 100rpm looking like it's trying to relearn the idle but it does it every start and between stopping when driving here and there.
How many O2 sensors are connected? 1 or 2?
Make sure the correct upstream 02 sensor is plugged in, If you have a OBD2 and are using a cat delete most likely you have 1 O2 bung in the header or test pipe so make sure that O2 sensor is plugged in the Up stream bank1 O2 sensor plug, Bank2 can be left deleted but this will usually cause a check engine code but has no affect on performance. Check the wiring to the 02 sensor has no breaks. If the cable touches metal it could short out which is what it sounds like,
check the harness and look for any cuts in the wires or plug. Unplug the neg battery to reset the ECU after connecting the O2 sensor plug when you check for any breaks or damage to the harness.
Is this OBD1 or OBD2?
Or run a OBD1 ECU with a jumper harness .
Oh yeah this does seem like it could be the issue! But just to make sure before I got ahead, if I only have the o2 sensor that I have plugged in it won't throw a check engine light but if I unplug that one it does and runs fine. Either way it changes without their being a 2nd o2 sensor
