New GTX3071R Gen2 weird sound
Old Sep 30, 2019 | 06:31 PM
piggy96's Avatar
Default New GTX3071R Gen2 weird sound
I just installed a new gtx3071r.,4an feed from sandwich adapter and vibrant oil restrictor bled the feed before startup. I have only had the car idling and reving to about 2500, not even driven yet as I’m setting up my base map, bleeding coolant etc. When I give a quick rev or shut the car off and the turbo is spoiling down I’m getting a weird sound coming from the turbo. I don’t know if I’m being paranoid and not wanting to screw up a brand new turbo or something is wrong. Never heard this sound from my T3/t4 turbo. Anyone have this before?
(trying to upload vid)
Old Oct 1, 2019 | 03:05 AM
Txdragon's Avatar
Default Re: New GTX3071R Gen2 weird sound
Wheel is still spinning. Those ball bearings keep rollin! I dunno if it may be a tad dry or not, somebody else may comment on the sound itself but otherwise, this is completely normal.
Old Oct 1, 2019 | 03:55 AM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
Sounds dry to me. I would remove the oil feed line off the turbo and stick it into a bottle and unplug the ECU then turn the motor over until there is oil pressure. At least you will know for sure if there is oil pressure or not at that point.
Old Oct 1, 2019 | 07:27 AM
TheShodan's Avatar
Moderator
Sounds completely normal. it isn't "dry" or anything else. It's just the ball-bearings making contact with its cage while still spinning. This must be your first Garrett ball-bearing turbo with a ported shroud!
Happy Boosting!
Old Oct 1, 2019 | 08:00 AM
piggy96's Avatar
Thanks for the replies guys! This is exactly what I was hoping to hear. I’ll bleed the feed line again just to be on the safe side. @TheShodan yes it definitely is lol. My last one was a custom T3/T4 built by cherry turbo, no ported shroud. Definitely some new sounds to me. I’m just being a little over cautious I guess.
Old Oct 1, 2019 | 08:09 AM
Txdragon's Avatar
The pucker factor gets pretty high when working with new ****. Lol! I've noticed on my ported shroud JB there's a bit of "wind down" when I shut the engine off. It doesnt last nearly as long as a BB does, but it happens. I spooked a little too. Lol.
Old Oct 1, 2019 | 03:12 PM
TheShodan's Avatar
Moderator
Ya'll just ain't used to quality ****, that's all...
no need to rebleed anything. don't go fixing stuff that ain't broken
Old Oct 1, 2019 | 03:15 PM
Txdragon's Avatar
I expected it, sir! Lol!
Old Oct 2, 2019 | 01:03 AM
Balor_Gr's Avatar
Come back with dyno numbers!
Old Oct 7, 2019 | 06:30 PM
piggy96's Avatar
hopefully tuning end of this week or next week and will post the results. With everything I’ve done in the past couple months I should’ve done a build thread.
Old Oct 8, 2019 | 09:30 AM
Balor_Gr's Avatar
Yeah make a quick "résumé" build thread. I like the turbo you decided to use.
alperx
May 5, 2013 09:32 AM
xlasianizelx
Jul 11, 2010 10:19 PM
jdm_vtec
Sep 23, 2007 03:16 PM
90LSpimpin
Jun 30, 2006 10:13 PM
komat
Oct 8, 2005 12:00 AM
