Wheel alignment question
Old Sep 26, 2019 | 09:18 AM
oldman9's Avatar
Default Wheel alignment question
Hello. So I FINALLY got time off to swap out my busted power rack for a manual one. I'm using alignment plates to get it close enough to drive to the real alignment shop. Just making sure that I'm using these things correctly.
Old Sep 26, 2019 | 09:50 AM
spAdam's Avatar
Loved
Community Favorite
Default Re: Wheel alignment question
That’s pretty much it. If the wheel is straight I wouldn’t even bother with the alignment shop. Assuming your garage floor is decently flat, the resolution on those tapes is as good as any alignment shop is going to be.
Old Sep 26, 2019 | 03:08 PM
oldman9's Avatar
So it looked ok in my garage, but it was kind of rough once I got on the road. I was way off on the steering wheel. It's like a new car now tho.
Before
After
Old Sep 29, 2019 | 07:34 AM
JimN's Avatar
Looking at your toe plate and alignment pics, from where I'm sitting, if you are going to keep using the plates it looks like you need think about what your doing wrong. The tape measure was sagging in the middle or hanging up on the backside, the toe plates are warped, they were strapped on to tight causing them to bow, just propped up against the tire and they slipped a little, not compensating for tire and wheel runout, etc, something is wrong.
I do not think your total toe should have been off by over 4*. My mistake, I meant 1*.
Old Sep 29, 2019 | 11:28 AM
spAdam's Avatar
Loved
Community Favorite
Toe plates to me are nice for a quick check or use at the track, but you really need to build a string box if you’re going to diy at home. I built a setup a few years back and it worked great, I just don’t have access to my garage to do work anymore.
Old Sep 30, 2019 | 02:26 PM
tony_2018's Avatar
Fish Twig
PICS OR IT NEVER WAS BUILT.
Old Sep 30, 2019 | 03:06 PM
spAdam's Avatar
Loved
Community Favorite
https://honda-tech.com/forums/suspen...level-3128246/
Edit - I see photobucket finally permafucked their images
Old Sep 30, 2019 | 04:31 PM
tony_2018's Avatar
Fish Twig
Old Sep 30, 2019 | 05:38 PM
JimN's Avatar
That is a nice setup. It's not something I'm going to build or buy for myself. The 97 f150 & the 97 del sol we have don't even qualify as daily drivers since I retired. After I finish the steering, suspension, and alignment work on both of them I do not think I will need to mess with them for a long time.
Regards, Jim.
Duc_du
Suspension & Brakes
May 24, 2009 09:05 AM
Killtodie
Honda Civic (2001 - 2005)
10
Jul 10, 2008 01:50 PM
Acco12dv6
Jul 13, 2007 01:29 PM
Nothing.Special
Suspension & Brakes
May 23, 2005 08:08 AM
FBP Si 2000
10
Jul 15, 2004 10:46 PM
