Head Stud Timeserts Crooked?
Old Sep 23, 2019 | 01:34 PM
MotorMouth93's Avatar
10 Year Member
Default Head Stud Timeserts Crooked?
I installed head stud timeserts in my C30A engine block since the factory threads are prone to pulling out even without overheating and I'm upgrading to ARP hardware and MLS head gaskets which require more torque than the factory spec for the OEM graphite gaskets.
I had a custom alignment tool made to perfectly align the timesert drill plate with the holes in the deck because the included alignment pin is too small for the holes in the C30 deck, the tool worked perfectly, installation was time consuming but overall went smoothly.
I went back and measured how straight each insert is relative to the deck surface just to satisfy my repressed OCD tendencies and the worst was 0.6-0.75 degrees from perpendicular. There is enough wiggle in the head studs to get them perfectly straight and still thread in easily. As far as I can tell, I did everything right according to the directions and the only thing that could have caused this would be the play between the timesert drill plate, bushing, and drill bit. How much angle in the studs is too much?
Worst case scenario I'll just have the shop doing the block machining pull them out and do bigserts.
I'm done with trying to do stuff like this myself though, I should have realized that DIY timeserts are more for fixing an overheated corolla engine block in an autozone parking lot than for building a performance engine and left it to the pros who could get it 100% perfect. Live and learn I guess.
Old Sep 23, 2019 | 09:54 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Head Stud Timeserts Crooked?
Put it together and send it !!! It should be fine.
Old Sep 24, 2019 | 02:54 PM
the_unknown's Avatar
GDD Lonely Krew
Only a REAL NSX owner would measure how perpendicular their head studs are to their block in tenth of a degree increments lol. I think you're good brother
Old Sep 25, 2019 | 01:15 PM
Chance EG's Avatar
Drive that NSX by my apartment when you get the engine back together
Old Oct 25, 2019 | 09:42 AM
10 Year Member
You guys were right. Machinist said it was no problem and that the holes were likely drilled crooked from the factory. Bottom end is about to be reassembled.
Photos from machine shop.
View this post on Instagram
Rasmusm
May 26, 2013 05:02 AM
DC2-ProdUcTiOnS
Oct 27, 2011 02:07 PM
The93egg
Mar 1, 2009 11:02 AM
GSR_hatch936
May 27, 2008 06:09 PM
80884
Dec 8, 2004 04:09 PM
