B16 Civic rough startup
Old Sep 22, 2019 | 04:19 PM
eg6noise's Avatar
Default B16 Civic rough startup
Hi, my B16 is acting up on cold starts. The tach shoots up to about 3000rpm right after it cranks, but idles up fine at about 1500-1000 rpm about a couple of seconds after. I've watched some videos that show cold starts and it cranks smoothly and shoots up to 1500rpm max, then idles right after. I know it isn't anything major but it puts unnecsssary strain at the bottom end as the oil pump needs a couple of seconds to build minimal oil pressure and it's not exactly a new engine at 136k miles. I'll check the main bearings on the next oil change as I've also noticed a louder mechanical noise that lasts for a second when it starts up. FITV is deleted using a gasket and the coolant line has been rerouted, IACV has been already cleaned and inspected. Oil pressure is fine, about 4-4.5 bar (58-65 psi) on cold starts with a 1000-1500rpm idle. I really don't know what else to check, already checked for vacuum leaks and couldn't find any.
DumpdEJ6
Sep 23, 2019 04:48 AM
DumpdEJ6
Dec 11, 2016 06:26 AM
spoolinlude
May 26, 2011 05:46 AM
j-robsDA
Jun 20, 2005 07:39 PM
Chuck Norris
Oct 28, 2002 06:24 AM
