1990 acura integra shifting problem
Old Sep 19, 2019 | 07:26 AM
Bryce Yandell's Avatar
Default 1990 acura integra shifting problem
ok thank you by any chance you know what my problem might be because my car i have to yously put it into 5th then 4th and so on before it will go into first, i thought it would be slave cylinder forsure but sence it dosent have slave cylinder was hoping so beacuse cheap fix but you have any ideas?
Old Sep 19, 2019 | 08:01 AM
1990IntegraLS's Avatar
Default Re: 1990 acura integra shifting problem
Mine does this some, but especially if it's not warmed up and hasn't dropped down to low idle.
The only other thing you can try is adjusting your clutch, but you must be careful not to adjust it too far, so it starts slipping.
Let it warm up and drop into low idle, see if that does it.
Bryce Yandell
Sep 20, 2019 06:30 AM
EJ6sedan
Aug 1, 2009 11:59 PM
mmvito
Jan 23, 2008 02:30 AM
91civ
May 14, 2002 11:07 PM
