What ECU for B18c EG?
Old Sep 17, 2019 | 09:53 PM
Brembomaster's Avatar
Default What ECU for B18c EG?
Hello,
I got code 20 (ELD) and code 23 (knock sensor) with the P73 ECU. I has replaced the knock sensor but code has not gone and I pretty sure all the sensor are in good condition and no error with power fc.
I heard many people the would run with P28 and it is the best for swapped engine. Could P28 disabled the knock error code?
Or other ECU should be better you suggest?
Thanks!
Old Sep 18, 2019 | 05:00 AM
NoKz's Avatar
Default Re: What ECU for B18c EG?
A chipped P28 can disable those sensors. Run one in my DC4 and one in my buddies B16 swapped DC2.
Old Sep 18, 2019 | 02:56 PM
egsleepercivic's Avatar
Did you run the wire for the knock to the ECU?
The knock wire from the factory is shielded wiring
also is the B18c gsr or type r spec ?
I think the ELD is part of the underhood fuse box
how are you running the obd2 ecu? i am assuming a jumper harness ?
Old Sep 18, 2019 | 05:05 PM
It's a strange thing, there are no knock sensor and ELD wire connect to ECU plug, Now , I had rewire the knock sensor to ECU directly, Code 23 has gone.
I will re-wire the for ELD . But I don't know where is it located and the ELD wire path.
Old Sep 18, 2019 | 05:29 PM
here is the pin out
it looks to be on connector D
https://technet.ff-squad.com/wiring.obd1.htm
Old Sep 18, 2019 | 05:41 PM
here is the pin out
Thanks for your help.
I know which pin for the ECU input it is. I don't know which one is the ELD signal wire to jump to ECU.
Old Sep 18, 2019 | 06:27 PM
May be there are no ELD circuit on my JDM version? What do I do to disable the eld or delete the code20?
Old Sep 18, 2019 | 07:06 PM
tony_2018's Avatar
Fish Twig
is this a jdm eg?
Old Sep 19, 2019 | 12:15 AM
Originally Posted by tony_2018
is this a jdm eg?
Yes, JDM
Old Sep 19, 2019 | 05:41 AM
spAdam's Avatar
Loved
Community Favorite
Your chassis has no ELD. You can software disable it on a chipped ecu. If that is not an option for you, you might be able to make a voltage divider circuit with a couple of resistors that outputs about 2 volts the the ELD pin at the ecu.
Old Sep 19, 2019 | 05:06 PM
tony_2018's Avatar
Fish Twig
well......look into how to wire one in i guess....
Old Sep 19, 2019 | 06:23 PM
is it should be below the fuse box?
Old Sep 19, 2019 | 08:40 PM
spAdam's Avatar
Loved
Community Favorite
It’s integrated into the usdm fuse box. That’s likely the most complicated solution.
cadwiese
12
Dec 6, 2008 02:00 PM
Trygge
May 14, 2004 09:16 PM
Defi4nce
Apr 25, 2004 10:01 AM
wizzards581
Apr 23, 2004 11:23 PM
